using own router instead of eero
emmck
Message 4 of 4
hi,
I have an eero router, however it will not allow our Orisec alarm to connect to their internet cloud server.
 I need to replace the eero router with a draytek/tplink to make this work. What router settings do I need to use.
any help appreciated or if talktalk technical could contact me.
3 REPLIES 3
Message 1 of 4
How are you getting on?
Message 2 of 4
@emmck
Access to a cloud server should not be restricted by router, have Orisec told you that the eero is incompatible?
Message 3 of 4
Details can be found here
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
