very slow broadband speed
vojkin
Message 3 of 3
Hi . I've Fibre 65 and I have been getting a speed of 1-2Mbs on each device connected to the router. Ive done all checks and no changes. Please help
Message 1 of 3
I'm sorry for the delay. I've run a test on the line which hasn't detected a fault and the sync speed looks ok. Are you running the speed test wired or wireless? Could you also try powering down the router for a full 30 minutes and then retest again as this will retest the current session and can often increase the speed.
Message 2 of 3
2. What is the speed measured by the router? If you log into it this is normally displayed in the initial dashboard area if it is a Wi-Fi Hub.
3. If you have any wired connections, are they affected in the same way as wireless ones?
