on 02-04-2024 12:26 PM
Hi i have ordered 150 fibre broadband my question is will my hg633 router connect to eero6 router? for my ethernet 4 cables.
on 03-04-2024 07:50 AM
I'm sorry for the delay. Yes, this should be fine. There's no need to get a new router.
on 02-04-2024 12:44 PM
Hi Michelle
Thanks for that info will any gigabit network switch be ok or is it best to get new router
on 02-04-2024 12:32 PM
Thanks for your post. The HG633 router won't work with the eero. If you need additional ethernet ports then we recommend purchasing an ethernet/network switch.
