Best way to be able to use a lot of devices.
Susan5050
Message 24 of 24
Not knowledgeable on technology so excuse my basic explanation.
I have fibre 150 VoIP the eero didn't work though so I was sent a normal router which means I can't do a lot of things like speed test or look at faults etc.
I would like to connect some new devices but am unsure how many I can already connect with my set up?
Also I know in my home there is what I believe is called a dead spot due to wall insulation. This is not affecting anything I am using currently but if I add devices I might want to sort this issue so how could I do that?
23 REPLIES 23
Message 21 of 24
Hi @Susan5050
Thanks for the info, you either have the Sagemcom FAST5364 or the Sagemcom FAST5464 (where the phone plugs into the rear of the router). It doesn't really matter which of the two that you have.
Considering the number of devices you can connect is difficult to predict with any certainty. It all depends on how much data they will be sending or receiving, plus how fast your fibre speed is etc. On Full Fibre 150, that part shouldn't really be an issue. Is the WiFi coverage in your home OK, or do you have any dead spots? How many devices do you want to connect & what sort of things are they?
Message 22 of 24
Thank you for your reply.
I'm not sure what my router is it has a orange colour behind the frame dots at the front.
If was a BT engineer that first set the erro router up but he said he couldn't do it properly so I was left with nothing working. Another  BT engineer was sent out but unfortunately he also said he couldn't do it if I remember he did connect me back to my old router to leave me with something (can't really remember now).
I was sent out this current router and paid for a private engineer to set everything up as I can't do any of that myself. I also had to do that quickly as when I'm left with no internet it's a huge problem as I need to have a landline and various important things connected so I couldn't risk trying about with the eero.
Message 23 of 24
Hi @Susan5050
I can help with all aspects of routers & WiFi etc, which make/model of router do you have currently? Was any investigation done with your eero (or eeros) in terms of WiFi coverage (probably by myself)?
