Need another Eero box
Jennyr231
Message 3 of 3
Is there a way to get another Eero router as 2 only 2 ports on the back isn't enough
Message 1 of 3
Thanks Keith
Message 2 of 3
Hi @Jennyr231
If all you want is more Ethernet ports then buy a small Gigabit data switch with enough ports on it, such as this example:-
https://www.amazon.co.uk/TP-Link-LS1005G-Wallmount-Ethernet-Splitter/dp/B07VWB347G/ref=sr_1_3?crid=2...
Then connect the spare Ethernet port to the switch and all other Ethernet devices (including the Grandstream DVA if you have one) to the spare ports on the switch.
