Thursday - last edited Thursday
I have received an email from TalkTalk saying that Callsafe will shortly be chargeable. As far as I am aware, as I am using VOIP (digital voice) and call safe is not avaiable, I am assuming this is an error and no additional charge will be made to my account.
Friday
Thanks again for your reply I noticed that @Gliwmaeden2 has flagged the issue up perhaps you could escalate it ? I am much too busy at the moment to make long phone calls, it is a general issue with any luck it should be sorted at some point.
Thanks for your help
Friday
I understand, is there anything else we can assist you with?
Friday
Thanks ,I don't want it cancelled just to be able to control it through my account !
Thanks for your reply
Friday
@davidl1 can I ask that you please contact the full fibre team for further assistance they will let you know what is going on.
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Friday - last edited Friday
Thanks for your reply, we are going round in circles !! when I log into my account I am told callsafe isn't available as I am using digital voice, even though it is enabled and working on my account. (Please see below) others have reported the same, therefore there is no option on 'manage your package' to manage it. It seems to be a system problem.
once again thanks for your reply
David
Account number:
xxxxxxxxxxxxx
Phone number:
xxxxxxxxxxxxx
Need Help?
Friday
Yes @davidl1 you are using VOIP. You should be able to use it as @Gliwmaeden2 has mentioned it available to TalkTalk customers, it does not state that you are unable to use it if you have full fibre.
https://community.talktalk.co.uk/t5/Articles/About-CallSafe/ta-p/2204784
Friday
Hi Thanks for that, that is good news ! I dont seem to be able to manage it from my account, the system is telling me as I am using Voip its not avaiable to me, assuming this will be sorted at sime point.
Friday
@davidl1 callsafe is active on your account.
Friday
Hi @davidl1 I will check your account and confirm if you have callsafe.
Friday
It is very confusing, @davidl1, particularly as some Talktalk published advice suggests that Callsafe is available to ALL customers!
This is a recent article:
https://help-centre.talktalk.co.uk/Telephone/Telephone_security/How_do_I_manage_nuisance_calls
So we need clarification on this and it is being flagged up.
Friday
It all seems confusing, i have dialed 1472 on my landline callsafe does seem to be active, even though i am on Voip, its all very conflicting ! TalkTalk say callsafe is not available on Voip, also it is no longer suported, now we are told its £1 a month to support it ! I am confused, sure I am not alone !!
Thursday
It isn't with VoIP services. But if you do not proactively cancel it now you may nevertheless still be charged going forwards, so will have to untangle it at a later date.
Thursday
Hi Thanks for that, yes i have had callsafe on a previous package, hopefully TalkTalk staff will pick my question up from here, I was under the impression callsafe was not avaiable on new packages ?
Thursday
I am on Full Fibre and have neither a red banner as you describe, nor have I received an email. Have you ever had CallSafe active on a previous package? To be on the safe side, personally I would contact customer services directly to check and remove if necessary.
Thursday
Hi, Thanks for that, When i log into my account there is a red banner accross the top saying after Jan there will be a charge with a link to call safe, clicking the link tells me callsafe is not avaiable on digital voice, callsafe is not not shown elsewhere in on the my account settings. With any luck its a generic email sent in error !
Thursday
Hi @davidl1 we are assured this is the case, but to be on the safe side check in my account to make sure it is not selected.
