Callsafe email
davidl1
Super Duper Contributor
Message 34 of 34
 I have received an email from TalkTalk saying that Callsafe will shortly be chargeable. As far as I am aware, as I am using VOIP (digital voice) and call safe is not avaiable, I am assuming this is an error and no additional charge will be made to my account.
David
33 REPLIES 33
Message 21 of 34
@davidl1 can I ask that you please contact the full fibre team for further assistance they will let you know what is going on.
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Phili
davidl1
Message 22 of 34
Thanks for your reply, we are going round in circles !! when I log into my account I am told callsafe isn't available as I am using digital voice, even though it is enabled and working on my account.  (Please see below) others have reported the same, therefore there is no option on 'manage your package'  to manage it. It seems to be a system problem.
once again thanks for your reply
David
CallSafe
CallSafe is our calling feature to stop unwanted calls. Find out more about CallSafe here.
Account number:
xxxxxxxxxxxxx
Phone number:
xxxxxxxxxxxxx
CallSafe isn't available with Digital Voice
You currently have Digital Voice, which uses your broadband connection instead of a traditional landline. Because of this, CallSafe is not available on your service.
Need Help?
Find help, features, guidance and support for your account and services.
David
Message 23 of 34
Yes @davidl1 you are using VOIP. You should be able to use it as @Gliwmaeden2 has mentioned it available to TalkTalk customers, it does not state that you are unable to use it if you have full fibre.
https://community.talktalk.co.uk/t5/Articles/About-CallSafe/ta-p/2204784
Phili
davidl1
Message 24 of 34
Hi Thanks for that, that is good news ! I dont seem to be able to manage it from my account, the system is telling me as I am using Voip its not avaiable to me, assuming this will be sorted at sime point.
Thanks for your help
David
Message 25 of 34
@davidl1 callsafe is active on your account.
Phili
Message 26 of 34
Hi @davidl1 I will check your account and confirm if you have callsafe.
Phili
Message 27 of 34
It is very confusing, @davidl1, particularly as some Talktalk published advice suggests that Callsafe is available to ALL customers!
This is a recent article:
https://help-centre.talktalk.co.uk/Telephone/Telephone_security/How_do_I_manage_nuisance_calls
So we need clarification on this and it is being flagged up.
davidl1
Message 28 of 34
It all seems confusing, i have dialed 1472 on my landline callsafe does seem to be active, even though i am  on Voip, its all very conflicting ! TalkTalk say callsafe is not available on Voip, also it is no longer suported, now we are told its £1 a month to support it ! I am confused, sure I am not alone !!
David
Message 29 of 34
It isn't with VoIP services. But if you do not proactively cancel it now you may nevertheless still be charged going forwards, so will have to untangle it at a later date.
davidl1
Message 30 of 34
Hi Thanks for that, yes i have had callsafe on a previous package, hopefully TalkTalk staff will pick my question up from here, I was under the impression callsafe was not avaiable on new packages ?
David
Message 31 of 34
I am on Full Fibre and have neither a red banner as you describe, nor have I received an email. Have you ever had CallSafe active on a previous package? To be on the safe side, personally I would contact customer services directly to check and remove if necessary.
davidl1
Message 32 of 34
Hi, Thanks for that, When i log into my account there is a red banner accross the top saying after Jan there will be a charge with a link to call safe, clicking the link tells me callsafe is not avaiable on digital voice, callsafe is not not shown elsewhere in on the my account settings. With any luck its a generic email sent in error !
David
Divsec
Message 33 of 34
Hi @davidl1 we are assured this is the case, but to be on the safe side check in my account to make sure it is not selected.
