Can I get a phone that does not require a digital voice adaptor
user10101
Message 5 of 5
Hello, I have recently moved to full fibre and I am using the digital voice adaptor to connect my eero to my phone base set. Is it possible to get a digital phone with an ethernet socket so that I can connect the eero directly to a phone base set? Hence removing the need for a digital voice adaptor.
4 REPLIES 4
Message 1 of 5
When using VOIP with the eero, the digital voice adapter is required.
user10101
Message 2 of 5
Thanks, I was looking for this option just for simplicity. I have been told by TalkTalk to use the eero router with full fibre and its been setup by the engineer. Sounds like something Talk Talk may market in the future. I called TalkTalk about this suggestion but they did not know and told me to continue with the adaptor.
mrwrighty
Enlightened One
Message 3 of 5
Unfortunately TT do not disclose the SIP configuration for VOIP so there is no chance of adding a 3rd party VOIP adapter or VOIP phone to the TT network.
Message 4 of 5
TalkTalk do not market such a phone and I don't know the spec of the digital voice adapter to recommend anything compatible.
Another alternative would be to get a Sagemcom Hub 2 (FAST5464) as that has the phone port built into so no adapter required. You could try asking the loyalty department if you could swap it out & return the Error & ATA.
