on 29-10-2024 02:39 PM
I have bought a Mondaine Stop2Go clock that needs to connect to Wi-Fi to be able to set the time and also keep it updated to the correct time. I am on TalkTalk Full Fibre 500 and I use a 3 X EERO mesh. The problem is that the clock will not connect to my Wi-Fi. I am hoping that someone might be able to help as to why my clock will not connect to my Wi-Fi.
I am using an Iphone 12 to make the clock/Wi-Fi connection
I bought the clock a couple of days ago and after fitting the batteries, followed the Mondaine connection instructions. The clock finds my Wi-Fi, I enter my password, save the settings, wait and then I get a message saying "didn't connect try again".
I took the clock to another house and tried it there. This house uses Vodafone broadband service (fibre to the cabinet), and has a seperate router and a 3 X Tenda Mesh system. The clock successfully contected to this Wi-Fi without any issues and set itself. This confirms that the clock functions OK and the problem is with my Wi-Fi.
I have tried to do this connection around 50 times now over 2 days and it seems clear that it is not going to connect.
The clock says it needs to communicate at 2.4ghz.
These are the fixes I have tried so far, without success:-
1) Talked to the clock supplier for help. The say "it should connect to your internet -- there is something wrong at my end"
2) Powered down and re powered up my 3 X EERO's
3) Entered the EERO app and went to troubleshooting -- turned off 5G for the allowed 10 minutes
4) Entered the EERO app and went to troubleshooting and turned ON legacy mode (non Wi-Fi 6)
5) Took out 2 X EERO's and tried to connect using only 1 X EERO
6) EERO app software update to latest one (yesterday)
7) Tried doing the Wi-Fi connection using an alternative iPhone
Below is a picture showing the clock setup page on my iphone with the error.
App error
I am now out of ideas. It appears that there was one other person that posted a similar issue to mine who reported that he eventually got his clock to connect.
Andrew
on 31-10-2024 12:12 PM
Hi Andrew,
How are you getting on, has Keith's advice helped?
on 30-10-2024 11:48 AM
Hi @Andrew2002
As the clock only supports the 2.4GHz band & it connects via an app, you will need to pause the 5GHz band temporarily.
This is done in the eero app by going to:-
Settings > Troubleshooting > My device is 2.4 GHz only and tap Temporarily Pause 5 GHz.
There is now a 10 minute window to connect your clock.
30-10-2024 11:19 AM - edited 31-10-2024 12:11 PM
Thanks ferguson
Hi Andrew, I can see that you've no updated your profile, could you just confirm that you're still unable to connect the clock
on 29-10-2024 08:08 PM
It still doesn't look like your profile contains the necessary information, have you included your account number?
And just to check: when you temporarily paused the 5GHz band did you actively try to connect the device at that point via the app?
I have also moved this to the Full Fibre section where it is more appropriate.
@Chris-TalkTalk for information.
on 29-10-2024 03:29 PM
Hi Andrew,
Sorry but I'm not seeing the information requested in your Community profile, if you've entered it, it doesn't appear to have been saved
on 29-10-2024 03:18 PM
Profile updated.
on 29-10-2024 02:58 PM
Hi Andrew,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
