Connection Status of Full Fibre/Track My Fault
Billx
Message 31 of 31
Attached
30 REPLIES 30
Message 21 of 31
Can I just confirm, are you trying to run a speed test or a line test? We're still working to bring the line test functionality in My Connection to Full Fibre customers. Is the overall performance of your connection/speed ok?
Message 22 of 31
Thanks Gliwmaeden2. That's a much more sensible answer than one I got earlier.
Gliwmaeden2
Message 23 of 31
Wait for staff to run some line checks just in case there is something that the My Connection software is picking up  - they will be back on Monday, @Billx.
I too find the checker sometimes confusing, and sometimes faults fall off when nothing's been done, so it's difficult to know whether to believe its results, or non results!
Message 24 of 31
Also, if I go to https://support.talktalk.co.uk/fault-timeline/REP-12945353  or https://support.talktalk.co.uk/fault-timeline/REP-12957367,
I get the following response:
We’ve run into a problem
Sorry, we’re working hard to resolve this issue.
Please try again later.
It says that there is an issue, and they working hard to resolve the issue. Don't you think that requires attention?
Message 25 of 31
No there does not appear to be anything wrong on my side, but  there appears to be something wrong on TalkTalk's side. Either they are misdiagnosing, or they correctly diagnosing and not fixing the problem.
Message 26 of 31
And have you noticed anything wrong? That could just be an issue with the test itself.
Message 27 of 31
When I go to https://support.talktalk.co.uk/ ,  and click 'Run a connection test', I get the following:
Sorry, we had a problem checking your services
We tried to test your network connection but we can’t provide status updates on your current package.
Obvious, someone has to get TalkTalk to check their system.
It seems there's something wrong with my connection, but they are not fixing it.
Message 28 of 31
Yeah I did, perhaps I am missing your point?
Message 29 of 31
Thanks Ferguson. My account is working normally. The responses I get from TalkTalk web site are negative, as you will see, if you open the attached file.
Message 30 of 31
So is there an issue with your service, or is My Account just not working?
