yesterday
We have Full fibre 900 and VOIP via a Grandstream adapter, since yesterday conversations keep cutting out and then back in, usually meaning we have to use our mobiles instead.
Paul
Answered! Go to Solution.
yesterday
Hi Paul,
I'm glad to hear this. Thank you and the same to you too 🙂
yesterday
Hi Michelle,
Just to let you know, resetting the Digital Voice Adapter worked, I must try an remember that it has a reset button, incase we have any further problems.
Merry Christmas and Happy New year to you all.
Thanks,
Paul
yesterday
Great thanks Paul 🙂
yesterday
Hi Michelle,
Thanks for the reply.
I've just reset it and will report back later.
Thanks,
Paul
yesterday
Hi Paul,
I'm sorry to hear this. Have you tried resetting the digital voice adapter and re-setting it back up again?
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
