Conversations keeps cutting out and then back in whilst on a phone call
Woody179!
Message 6 of 6
We have Full fibre 900 and VOIP via a Grandstream adapter, since yesterday conversations keep cutting out and then back in, usually meaning we have to use our mobiles instead.
Paul
5 REPLIES 5
Message 1 of 6
Hi Paul,
I'm glad to hear this. Thank you and the same to you too 🙂
Woody179!
Message 2 of 6
Hi Michelle,
Just to let you know, resetting the Digital Voice Adapter worked, I must try an remember that  it has a reset button, incase we have any further problems.
Merry Christmas and Happy New year to you all.
Thanks,
Paul
Message 3 of 6
Great thanks Paul 🙂
Woody179!
Message 4 of 6
Hi Michelle,
Thanks for the reply.
I've just reset it and will report back later.
Thanks,
Paul
Message 5 of 6
Hi Paul,
I'm sorry to hear this. Have you tried resetting the digital voice adapter and re-setting it back up again?
Resetting your Digital voice adapter
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
  1. Insert a pin or straightened paper clip into the hole labelled “Reset” on your Digital Voice adapter.
  2. Slightly push and hold it in for up to 20 seconds; or until all the lights, apart from the power light, switch off. Once this happens release the reset button.
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
