Wifi issues
njels
Message 9 of 9
Hi, does anyone know what the ongoing issue is? Since last night my wifi has randomly been dropping and not working despite all lights being on and the box being new. Did an in depth test on the website and they did say there’s an issue but no notes on what the issue is or how long it’ll take to be fixed, just wondering if anyone on here knows anything at all and could help.
8 REPLIES 8
Message 1 of 9
Hi @njels
You can also try using google DNS - 8.8.8.8  &  8.8.4.4  to see if this helps improve stability :
https://community.talktalk.co.uk/t5/Articles/Using-3rd-Party-DNS/ta-p/2205279
Message 3 of 9
Okay thank you. any idea where i might find live updates on it?
Message 4 of 9
OK, thanks for that. There are some issues with these routers at the moment which TalkTalk are investigating.
njels
Message 5 of 9
The wifi hub, photo attached as i’m not sure of its exact name
Message 6 of 9
@njels
Which make/model of router do you have?
Message 7 of 9
All lights stay on as if everything is working yes
Message 8 of 9
When you lose wi-fi are the ONT lights green?
