on 16-12-2024 05:07 PM
Hi, does anyone know what the ongoing issue is? Since last night my wifi has randomly been dropping and not working despite all lights being on and the box being new. Did an in depth test on the website and they did say there’s an issue but no notes on what the issue is or how long it’ll take to be fixed, just wondering if anyone on here knows anything at all and could help.
on 17-12-2024 08:45 AM
Hi @njels
You can also try using google DNS - 8.8.8.8 & 8.8.4.4 to see if this helps improve stability :
https://community.talktalk.co.uk/t5/Articles/Using-3rd-Party-DNS/ta-p/2205279
on 16-12-2024 07:36 PM
on 16-12-2024 07:30 PM
Okay thank you. any idea where i might find live updates on it?
on 16-12-2024 05:48 PM
OK, thanks for that. There are some issues with these routers at the moment which TalkTalk are investigating.
on 16-12-2024 05:44 PM
The wifi hub, photo attached as i’m not sure of its exact name
on 16-12-2024 05:29 PM
Which make/model of router do you have?
on 16-12-2024 05:24 PM
All lights stay on as if everything is working yes
on 16-12-2024 05:23 PM
When you lose wi-fi are the ONT lights green?
