tv
monty1888
Message 4 of 4
Hi there,
My name is Brian Montague and have been a customer for roughly eight years. My contract expires on 22/08/23 and I'm currently on the fibre 65 plus tv package. I would be more than happy to extend my contract as I have had a great customer service whilst with the company. The only issue recently is my youview box is constantly cutting off and receiving no signal but when I restart it it works fine again for a day or so. I would be more than happy to extend my contract if I could be sent the new youview tv hub. I've heard there is less issues with the new box.
Many Thanks Brian Montague
3 REPLIES 3
Message 1 of 4
How are you getting on?
Message 2 of 4
The new TV hub is only available to future fibre customers.
The 4k box is probably the box you will be offered.
It sounds like your hard drive may be failing.
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the support staff look at other alternatives.
TalkTalk now only supply non recordable boxes although the 4k one can record but only has one tuner so you can't record one channel and watch another unless you set up a separate feed to both box and TV, so it's best to try all alternatives if recording is important to you.
Hope this helps.
Gliwmaeden2
Message 3 of 4
You'd need to speak to Talktalk and get a new box as part of your renewal, @monty1888
You are within the last 3 months of your contract, so there should not be an admin fee if you renew now.
Usually you will get a better deal by phoning them up, rather than going via My Account offers & upgrades. Check comparison websites to aid negotiation.
Staff can't set up a new deal for you via the forum.
