on 30-04-2024 10:54 AM
Hi, my connection recently got changed to Fibre 150+VOIP as part of the CityFibre/TT changeover in my area.
The new router is having daily issues with multiple WiFi devices where, intermittently, they cannot load data. Eventually it will be fine again, or a fix can be forced immediately by toggling WiFi off/on on the device.
3 ethernet-connected devices are working fine, and speedtests are perfect (on both wired/wireless - when the WiFi is working). All lights on the ONT are normal.
I have tried powering down the router, waiting, then restarting. The issue comes back almost immediately.
From reading the forums I understand this can be caused by WiFi optimisation constantly changing channels etc, managed by the router/TT. If this sounds likely, please go ahead and disable, as I'm more than happy to manage WiFi settings myself.
Thanks in advance.
on 13-05-2024 11:59 AM
on 13-05-2024 11:24 AM
Hi Debbie, thanks for the update.
It's probably a long shot, but are you able to advise a time? I'll be at work and can't walk out meetings etc. I'm more than happy to continue with the text ticket system if this is more viable.
on 13-05-2024 08:40 AM
Hi adz18
Our faults escalations team have advised that they will be contacting you tomorrow 14/05.
on 10-05-2024 11:36 AM
on 10-05-2024 11:34 AM
Hi Debbie, thanks for checking progress again, appreciate it.
I replied to the automated text ticket with a recap of the problem, and received a reply they would check the case. I've had no further contact since this on Wednesday, but I'm sure it's in hand and am happy to wait.
on 10-05-2024 07:38 AM
on 08-05-2024 09:31 AM
Hi adz18
Oh great, please let me know how you get on once the team have contacted you again.
on 08-05-2024 09:29 AM
Hi Debbie, thanks for checking in. I was unavailable when they called but have received a text with a ticket and will follow up today, thanks for your help.
on 07-05-2024 02:53 PM
Hi @adz18
Our faults escalation team are attempting to contact you. Have you received a message from the team?
03-05-2024 01:53 PM - edited 03-05-2024 01:59 PM
Hi adz18
Our faults escalations team are now investigating this issue and they may contact you directly to discuss this further.
on 30-04-2024 11:01 AM
Hi adz18
I have asked our Devices Team to take a look at this and I will post back as soon as I have further information.
