Decommission of copper connections
TWH0857
Private Message TalkTalk PLUS
Message 8 of 8
I have just had a Full Fibre installation but the old copper wired connection and open reach box is still installed.
Who disconnects this?
7 REPLIES 7
Message 1 of 8
@TWH0857 Thank you for the update! If you have any further questions or need assistance with anything else, please don't hesitate to reach out.
TWH0857
Message 2 of 8
Good afternoon,
I have removed the aforementioned copper cable from my premises up to the openreach box and filled the hole on the window frame,
thank you for your concern!!!
best regards
Tom
Message 3 of 8
Hi @TWH0857 let us know if you still need assistance reagrding this.
Message 4 of 8
Up to and including the box is officially the property of OpenReach.
TWH0857
Message 5 of 8
I guess the box is also mine as its in the house!!! Wonder if I can sell on ebay....?
TWH0857
Message 6 of 8
Thank you for the response, so, it looks like it will be a "me" job!!!
Thankfully its mostly ground level.......
Message 7 of 8
I assume by disconnect you mean remove as the line should be disconnected from use at the same time as fibre was installed.
OpenReach are not removing old copper wire as standard. Generally any wires in your home after the box are yours to remove, up to the box are OpenReach property.
However I doubt that OpenReach will object if you remove wires within your property , at least I hope not as I've done this, and you could argue you were decorating and wanted to have a clean surface. Note personal opinion.
TalkTalk have no control over the removal of such lines.
If your external wiring is visible, such as from a pole, and you want it removed for decorating or building works, you can contact OpenReach direct and request the removal.
An online form to complete can be found here.
I expect OpenReach will eventually get round to removing old equipment, but their priority is getting customers connected to fibre and keeping the networks running.
