Dns not recognised
Tinaking
Message 4 of 4
When I am on search engine Google when I try click into sponsor pages it won't let me says dns not recognised this is on phone and ipads laptops every time
If anyone can help with this thank you  
3 REPLIES 3
Message 1 of 4
Disable eero Secure.
To enable or disable eero Secure, from the eero app go to:-
  1. Tap Discover
  2. Tap eero Secure
  3. Tap Advanced Security to toggle the feature on or off.
Message 2 of 4
It is eero yea it OK if I directly put in say ebay etc but not as a sponsor site
Message 3 of 4
What make & model of router are you using, is it an eero? Do these URLs resolve if entered directly in a browser on the device connected to the router?
