Does Sagecom Fast266 extender work with Eero 6 router?
Mxracer43
Message 5 of 5
Hi, I have recently upgraded to fibre broadband and have the Eero 6 router. I have a poor wifi signal in some parts of the house and on the old "non-fibre" system this was helped by using a Fast 266 wifi extender.  Can is use the Fast266 with my Eero 6 router to improve wifi coverage?
Kind regards Steve
4 REPLIES 4
Message 1 of 5
Morning @Mxracer43
Please can you add your name and TalkTalk account number to your Community Profile. I'm also sending you a Private Message.
Thanks for your help Keith 🙂
Message 2 of 5
Hi @Debbie-TalkTalk @Karl-TalkTalk @Anonymous @Chris-TalkTalk
This customer has had an F266 historically that was required to get reasonable coverage around the property, before upgrading to full fibre. He has been provided with one eero 6, would there be any chance of providing a second eero 6?
Message 3 of 5
Thanks Keith, I knew I could rely on you for the answer 😄
Kind regards Steve
Message 4 of 5
No, they are two different types of product.
