Eero 6 & Deco mesh
Jackie2901
Message 6 of 6
Hi I need some advice. Due to the way our house is set up  we only get good BB signal in the living room and use the TP-Link Deco Mesh system for everywhere else. Currently on fibre 60 plan that s is being upgraded to FF 150. So I need to know if my Deco system will still work on this Eero 6 otherwise it'll be an expensive 1 room broadband contract. Not really tech savvy so keep it simple 😁 thanks!!
5 REPLIES 5
Message 1 of 6
Yes you can continue using the current router with the deco mesh, speed should be fine
Message 2 of 6
Do you mean continue using the current router instead of the eero? If so will it cope with the higher speeds ok?
Thanks 😊
Message 3 of 6
OK thanks. I don't know if the deco mesh will work with the eero but if it doesn't your current router should work fine
Message 4 of 6
Hi Chris I have the Sagemcom-FAST5464 currently
Chris-TalkTalk
Message 5 of 6
Hi Jackie,
Which router do you currently have?
