Eero 6 pro as an extender
ColRe1
Repeat Guest
Message 2 of 2
I have Full Fibre 150 with a Eero 6 pro router. I'm installing an additional Eero 6 pro (supplied by Talk Talk) as an extender to eliminate bad signal in part of my house. My question is, as the Eero 6 pro used as an extender has two available network ports on it can these be used to make a wired connection to another device? specifically the Digital Voice Adapter, if it is possible then I wouldn't have to have the telephone base station with the main router.
1 REPLY 1
Message 1 of 2
Yes.
