Eero compatibility with Xbox series s
Francis 1
Message 3 of 3
Does anyone know if you can successfully connect an Xbox series S to the eero 6 router? This uses wi fi 5 which eero doesn't support?
Message 1 of 3
Hi @Francis 1
@Anonymous has asked me to help you. The Eero most certainly does support WiFi 5: as long with virtually all older standards.
What is your exact problem and I will try and resolve it for you.
Message 2 of 3
@KeithFrench - Would you be able to offer any advice please?
