Nat keeps changing on xbox series x
langy71
Message 71 of 71
Hi,for a few weeks now my nat keeps going from open to stricked.i have to reboot the router.
Any help
Paul Langford
70 REPLIES 70
Message 1 of 71
Hi langy71
Is everything still working ok since your last post?
Message 2 of 71
Hi langy71
I'm so glad to hear this. I will feed this back to our Devices Team.
Apologies for the issues you experienced.
langy71
Message 3 of 71
Hi,all working now on the old firmware.
Thanks to all for the help.
Paul Langford
Message 4 of 71
Thanks Keith, I've fed this back to the team.
Message 5 of 71
If it is working on the previous firmware, then this would at least prove that the UPnP bug that I reported to TalkTalk a while ago, was introduced with V174.
Message 6 of 71
Hi langy71
It's working ok after the firmware change? (Just so I can let our Devices Team know)
langy71
Message 7 of 71
Hi,thanks for that.it seems OK for now.
Paul Langford
Message 8 of 71
Obviously as they are different manufacturers their firmware is completely different as is the UI. However, the Huawei does not suffer from the UPnP bug, but there are other bugs outstanding with this router.
Message 9 of 71
langy71
Message 10 of 71
Hi,we have not tried the consoles yet.will test later.
Paul Langford
Message 11 of 71
Hi langy71
Did you test since the firmware was changed (yesterday evening)
langy71
Message 12 of 71
Hi,a friend has a spare so I can test.
Paul Langford
Message 13 of 71
Hi langy71
No this is different to the Sagemcom hub.
Are you still experiencing the same issue since the firmware was changed?
langy71
Message 14 of 71
Hi,does the Huawei DG8041W-2.T5 use the same firmware as the Sagemcom.
Paul Langford
Message 15 of 71
Hi langy71
Sorry for the delay.
Please can you retest? The change has been made to the firmware.
Message 16 of 71
That could well be down to pushing the previous firmware, wait until you hear back from TalkTalk, otherwise you might brick your router.
langy71
Message 17 of 71
The router has just gone off twice now.starts flashing orange.it stayed on for a few minutes then went off again.back on now.
Paul Langford
langy71
Message 18 of 71
It has been on all the morning.
Paul Langford
langy71
Message 19 of 71
The hub is on,I'm streaming YouTube
Paul Langford
Message 20 of 71
Hi langy71
They advised that the device appears to be offline, Is the router switched on at the moment?
Anonymous User
