Eero won’t connect to active internet
Donski2003
Message 17 of 17
TT sent new Eero.. my old hub is working fine!  The eero won’t accept incoming internet from my fibre modem. It works if I plug it into my old hub but not when plugged directly into the modem. I managed to register it that way and download updates. I checked my ip is set to dhcp , blab was enabled but I unchecked it and still won’t connect.  Tried the chat help but sat there for an hour and got nowhere (appalling).  Any ideas ?
16 REPLIES 16
Message 1 of 17
Morning Don,
Thanks for confirming. If you'd prefer to use the Wifi Hub instead of the eero then this would be fine, we won't stop the Wifi Hub from working. Please let us know if you do experience any issues.
Michelle 🙂
Message 2 of 17
I did get it to connect to the internet.. constant white light.  I re-assigned my Apple tv and got it working ok.. but connection times out back to solid red light.  After resetting everything it connected again.. I  tried connecting other devices, I am using the same network name and password but nothing else would connect. The connection to the internet then dropped back to solid red light.  Fortunately my old hub is working fine so I can continue to work with that.  Is there any reason i have to use the Eero?  ie: you will stop  my old hub from connecting?  it works perfectly well.
thanks for you help.. more helpful than the chat box has been 🙂
Message 3 of 17
Hi Don,
I'm sorry to hear that. Just to confirm, the eero connected but certain devices wouldn't connect?
Message 4 of 17
The eero needs a different configuration depending on network supplier details, it is "fit for purpose," but it may need tweaking remotely. Sadly, that seems not to have been effective here. Glad to hear that the Hub has got you back online though, feel free to return the eero.
Message 5 of 17
My old hub is still working so I have ditched the Eero.. it is obviously not fit for purpose.  Hopefully the old hub will continue to work.
Donski2003
Message 6 of 17
there doesnt seem to be away to actually talk to a person for help..  other than chat which was just crazy when i tried it.
Donski2003
Message 7 of 17
nightmare !  so it connected.. managed to connect apple tv by forgetting network and reassigning.. worked for 5 minutes.  PC woudnt connect, alexa wouldnt connect.  Then status back to red.  I tried resetting everything - factory reset the Eeero reloaded the app.. still on red..  Crazy.. havent tried using my old hub again which was working perfectly.
Message 8 of 17
Hi Don,
How are you getting on?
Message 9 of 17
Hello again,
Change requested so it should take around 15 minutes to complete. Please let us know if there is no connection by 2pm please?
Message 10 of 17
Ok, I'm just making the change now. When you lose connection on the wifi hub then connect the eero please.
Donski2003
Message 11 of 17
thats fine.. I can sit it out.. just go ahead .. the old hub is working fine currently.
Don
Message 12 of 17
Hi Don,
There would be a period of down time between the switch so if it could affect you working from home then it might be best calling our Tech Team at an convenient time to do this for you (evenings or weekends). Are you experiencing any issues with the current wifi hub at the moment?
Donski2003
Message 13 of 17
bearing in mind I work from home.. if you are confident this will work ok then yes that is fine.  I dont want to lose access completely 🙂
Don
Message 14 of 17
Thank you, I've found the issue. We would need to make a change to a profile on our side for the eero to work. The wifi hub would no longer connect following this, however the eero should then connect ok. Would you like us to make this change for you now? It can take up to 30 minutes to take effect?
Donski2003
Message 15 of 17
Hi Michelle.. I have updated my profile with my account number etc.. note I do not have a landline phone on the landline TT set up.  My modem was replaced recently by city fibre.
Message 16 of 17
Good afternoon,
I'm sorry to hear this. Was your FTTP connection set up by Openreach or CityFibre please?
  • Name
  • Telephone number or Account number
  • Alternative contact number
