yesterday - last edited yesterday
I have seen this mentioned in other threads but not discussed in detail so thought it best to start my own.
Am I correct in thinking that if your Full Fibre router breaks or will not connect to the internet for some reason but the ONT is is working and the right lights are showing green you can connect your laptop etc directly to the ethernet port on ONT and you will then have internet access through the ethernet cable while you wait for a replacement router to try, could someone confirm that is the case.
yesterday
Ah OK. As long as it's the router that fails, rather than the internet connection as you say.
yesterday
@ferguson wrote:Are you having any issues with your router at present?
No my connection has been fine but it will be nice to know if anything did happen to my eero i could use the ONT directly to gain access to the internet, many people depend on their internet for work if they lose it at the weekend its going to be Tuesday or Wednesday before a replacement router can be sent to test having one working ethernet connection would be a lot better than having no connection at all.
yesterday
I
@fr8ys wrote:Why not try it I was going to suggest, but I then did a google search and the answer is yes, you can.
I will give it a try tomorrow and see if it works.
yesterday
yesterday
