on 25-05-2025 12:11 PM
I have just ordered full fibre 150 and the email I received said that I have the correct equipment already , I have the hg633 , is this router suitable for full fibre
on 25-05-2025 04:51 PM
Not sure what to do now, will any one from talktalk on this forum be able to help , trouble is I marked as answered
on 25-05-2025 04:47 PM
I uploaded photos from the front and back of the router , the said rest assured it will work , was on chat for over an hour , so frustrating
on 25-05-2025 04:05 PM
Yes, it is suitable for fibre as in FTTC, but not Full Fibre FTTP. And it is an old model no longer issued in any event. It also looks similar to some routers that are. Did you not make clear that it was a Huawei HG633 and about the requirements for your new package? From what you have told us here I am not sure you have received correct advice.
25-05-2025 04:02 PM - edited 25-05-2025 04:20 PM
The information you have been given is wrong the HG633 will not work, here are two examples -
Will the Huawei HG633 work with Full Fibre 150?
on 25-05-2025 03:48 PM
So after a long chat , and sending photos of the router the have assured me that it's suitable for fiber , thank you all for you help
on 25-05-2025 02:41 PM
It would be quicker to get back to customer services to check with them directly, live chat is available today:
on 25-05-2025 02:05 PM
Can anybody on here help with this please
Thank you
on 25-05-2025 12:43 PM
Thanks for the reply , I don't need a landline , guess I need to speak to someone about a router
25-05-2025 12:32 PM - edited 25-05-2025 12:36 PM
The Huawei HG633 router is designed for ADSL2+ broadband, not full fibre.
If you need to use a landline make sure they are aware -
TalkTalk's Full Fibre broadband packages, including options with voice, offer a mix of speeds and features. You can choose a data-only plan (no landline) or add a voice line to your FTTP package. TalkTalk uses Digital Voice for landline calls, which use your full fibre connection rather than traditional copper lines.
