on 16-06-2025 09:23 AM
You have set me a new router and it works ok Thanks
But I cannot get my printer linked to it. I have tried a number of times using TALKTALK026D9A and NKJ49H64
Can you help
on 16-06-2025 09:38 AM
Hi there @DavidTogneri. Please try these below steps.
-Power on the printer and ensure it is within range of your Wi-Fi network.
-On the printer's control panel, navigate to the wireless settings or Wi-Fi setup menu.
-Select your Wi-Fi network from the list of available networks and enter the Wi-Fi password if prompted.
-Alternatively, if your router supports WPS, you can press the WPS button on your router and then on your printer to connect them automatically.
-Once connected, ensure your computer is on the same Wi-Fi network for wireless printing.
-These steps should help you successfully connect your printer to the internet.
on 16-06-2025 09:26 AM
Sorry typo NJK49H64
