on 30-12-2024 02:47 PM
We need a new free view box
on 31-12-2024 08:04 AM
How are you getting on?
on 30-12-2024 02:50 PM
If you mean YouView box, and one which records, TalkTalk no longer provide these.
What is wrong with your existing one?
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
If you wish to take this route, Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
Hope it works and please let us know how you get on.
on 30-12-2024 02:49 PM
Having problems switching channels our son says we need a new free view box
