on 06-10-2024 08:59 PM
Hi all. The gaming and conferencing setting on the eero app seems to have disappeared. No option to turn it on anymore for my son with his Xbox. It used to be on there. Any advice please.
on 25-10-2024 02:53 PM
Thanks Keith. Just seen. Thank you thought your time and help.
Regards Lee.
on 25-10-2024 02:48 PM
This has now been fixed in the eero app V6.49.0.36677.
SQM
on 19-10-2024 10:42 AM
HI @leenineplus
I have been looking into this more, in addition to the missing SQM option on my eero 6, I also noticed that UPnP was missing as well. @ferguson still had both on his eero Pro 6, so I thought that eero must have removed these features from the eero 6.
I contacted eero support & that was not correct, they are still there, but there is a bug in the eero app affecting some or all Androids (like my phone) & they are working on a fix now. Hopefully, there will be a new version of the app in a while that will restore these two facilities for Android users.
on 08-10-2024 10:36 AM
Hi @ferguson
Perhaps you have the option with the eero Pro 6, it was in my app for my eero 6 until yesterday lunchtime. The eeroOS was up to date before that, however, the app could have been updated & after lunch the option was goneit was gone.
on 08-10-2024 09:23 AM
Hi Lee,
Ok no problem. If you would like us to raise this then please let us know.
on 08-10-2024 09:21 AM
Hi Michelle. It's fine. Don't worry. All is good with the internet. I just thought that the option would have benefited the gaming side for my son but as it's so fast anyway, all appears good. I was just curious why the gaming and conferencing option had disappeared.
Thanks for all your time. Regards Lee.
on 08-10-2024 08:24 AM
Thank you. Did we also send you this eero? I can then escalate this over to our Devices Team again.
on 08-10-2024 08:21 AM
Hi Michelle. Please see attached.
on 08-10-2024 08:09 AM
Ok thanks. Are you able to provide a screenshot of what you can see when you try - settings, network settings, then SQM. Please do not post any personal information on the Community. If it contains personal information then send this to me via a Private Message please. Can I also just confirm that this eero was sent by us and not purchased separately by yourself?
on 08-10-2024 08:03 AM
It does.
on 08-10-2024 08:01 AM
Hi Lee,
Does your eero have the latest version of software/firmware?
on 08-10-2024 07:59 AM
Morning Michelle. I don't even have that on any part of the app. I've looked at every tab etc. Nothing. I think some features have been taken off. Mines on the updated app too.
Regards Lee
on 08-10-2024 05:55 AM
Does the SQM feature help at all?
07-10-2024 05:21 PM - edited 07-10-2024 05:22 PM
Hey, my own screen shows something different, as mentioned by Michelle earlier.
First this:
And then when I select SQM this:
on 07-10-2024 05:05 PM
Thanks Keith for your time and help. Regards Lee
on 07-10-2024 04:08 PM
I don't know if my app has just updated, it was there earlier today (I took a screenshot of it after lunch & it was there then), but as you say it is not there now. It was in the eero Labs section which was experimental, which has now gone. The other two options that were in there:-
are now in the main network settings, i.e. they are no longer experimental. I can only assume that they have dropped this facility altogether now.
on 07-10-2024 03:35 PM
Eero 6. 7.6.1-62. What you described there is no option. The gaming conferencing used to be there but disappeared.
on 07-10-2024 02:45 PM
What eero(s) do you have then & what firmware are they running? The Discover/eero Labs has been there for absolutely ages.
on 07-10-2024 01:46 PM
Hi Keith. I don't even have this option as you say. No discover/ eero labs etc
Discover > eero Labs > Optimise for conferencing and gaming
Regards Lee
on 07-10-2024 01:45 PM
Regards Lee
