Hub2 SG4K100174 port forwarding issue
mgajew
Message 8 of 8
Hi, having issues to setup port forwarding on my Hub2 SG4K100174 router and getting 'something wrong has happened' error.  Any idea if this is firmware version issue or something trivial I'm missing here. Thanks.
7 REPLIES 7
Message 1 of 8
Message 2 of 8
No problem, glad to help.
Message 3 of 8
Hi Keith,
yes resetting to factory defaults did the trick , thanks a lot.
Message 4 of 8
Can you try a factory default & also tell me what hardware revision you are on?
mgajew
Message 5 of 8
Thanks Keith, from the stick label at the back :
Device Ver: FAST 5464-2.T4
Message 6 of 8
I have just tried this & it worked first time. Is this definitely a Hub 2 (Sagemcom 5464), could it possibly be a 5364 & if so what hardware revision is it?
Message 7 of 8
I will have to test this tomorrow & get back to you.
