13 hours ago - last edited 13 hours ago
Hi @KeithFrench ,
I was wondering if you could send me your WI-FI optimisation guide please. I am on Fibre 900 and regularly get speeds of 940 to 950 MB on my Ethernet connected computers, but on my laptop and surface using a Wi-Fi connection only get speeds of between 300MB and 450MB.
I used to work in IT and therefore have knowledge in networking, but unfortunately my Wi-Fi knowledge is lacking.
Thanks,
Paul
Edited to add,
Sorry forgot to say, my laptop is Wi-Fi 6.
7 hours ago - last edited 7 hours ago
Hi Keith,
I've sent you a message with the screenshot. You're correct I do have two Netgear extenders in use because the Wi-Fi signal wasn't strong enough to reach the garage (car charger, that can only be connected via Wi-Fi) and shed (garden water feature smart plug). The Netgear unit that is connected to my switch is a XAV5201 and the two Wi-Fi extenders are both Netgear XWN5001 units. The Gateway eero is the one in the study on the 2nd floor.
Thanks,
Paul
8 hours ago
Hi Paul,
I have just started to have a quick look at this & first I need to have a look at exactly what APs you have. I can see the two eeros, but what are the MAC addresses of the gateway eero? That way I can identify which one is which. In the app, if you go to:-
Home > Gateway eero > Device information
Please can you get get me a screenshot of that page? It is probably best that you send this in a PM to me to preserve your privacy.
I can also see you have two Netgear extenders with the SSID the same as yours ending in _EXT & _ Ext1. What are the model numbers of these?
8 hours ago - last edited 8 hours ago
Hi Keith,
No problem, I'm grateful for your help and time. There's no hurry, I mostly use my desktop which is connected via Ethernet, but when I'm ill, I tend to use my laptop if I'm able.
Thanks,
Paul
9 hours ago
Hi @Woody179!
I may not have much time today to look at this for you, but I should be able to tomorrow.
10 hours ago - last edited 9 hours ago by KeithFrench
Hi Keith,
Thanks for the guide which was very easy to understand, I've attached the snapshot and report zip.
Thanks,
Paul
11 hours ago
Thanks Keith, I'll get back to you shortly. 👍
12 hours ago
Hi Paul,
No problem, the Pro 6 is a higher spec than the 6+ anyway. I just like to know what I am dealing with first.
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for my guide on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
12 hours ago
Sorry Keith, I got confused with the models, they are eero Pro 6 units.
12 hours ago
I am confused Paul, as TalkTalk to my knowledge, does not prove the eero 6+, only the eero 6 or the eero Pro 6 depending on the package you are on. Are you sure that they are eero 6+ units?
12 hours ago - last edited 12 hours ago
Hi Keith,
Both eero 6+ units were provided by TalkTalk, one eero unit is located in the study, which is located at the middle of the house at the back on the 2nd floor and the other unit is in the living room, again at the back of the house, but at the house corner near to the outside wall. I do also have VOIP which is plugged into the study Netgear 1GB switch.
Thanks,
Paul
12 hours ago
Hi Paul,
Thanks for that, please can I just confirm (it won't affect the level of help I am prepared to give) are these your own eero 6+ units or the TalkTalk-provided eero Pro 6 ones? Where roughly within the property are the two eeros?
12 hours ago
Hi Keith,
I have two eero 6+ routers set up and connected together via Ethernet. All the switches that I use for connections are 1GB.
Thanks,
Paul
13 hours ago
13 hours ago
No problem @Woody179! which router do you have?
