Monthly allowance
Weath
Message 4 of 4
What does monthly usage allowance mean.
It says £0 of £100 allowance spent. I have just been moved across from Shell so am struggling with the online account
3 REPLIES 3
Message 1 of 4
@Chris187
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
Chris187
Message 2 of 4
I want to change to £60 per month
Message 3 of 4
It's designed to stop you running up unexpected bills.
Details can be found here.
https://community.talktalk.co.uk/t5/Articles/Your-monthly-allowance/ta-p/2204660
