No Wireless Connection to any devices with Full Fibre
Lottie04
Message 37 of 37
I have been having long term ongoing issues with my Full Fibre ( Cityfibre ) since it was installed at the end of last year.  Currently all of my home devices are not working and All state NO INTERNET CONNECTION / WIRELESS CONNECTION i have spent hours even days trying to get someone at TalkTalk to resolve this issue but with no success. Can somebody Please ! try and help me.
These are my devices not currently working
SAMSUNG 4K TV
HUMAX FVP - 5000T which i bought as TalkTalk Youview box stopped working.
XBOX ONE
CANON PRINTER
My mobile has recently had no internet and  states connected without internet
Apart from the Youview box most of these devices were ok up to around April. I have spent a lot of time reading posts on here and it seems firmware can be an issue. How do i go back to a previous version?.
i always have 4 green lights on Full Fibre box and Solid white light on router.
Current Firmware  SG4K100174.
Best regards,
36 REPLIES 36
Message 1 of 37
Hi Lottie04
That's great, thanks for confirming 🙂
Lottie04
Message 2 of 37
Hi Debbie
It is thank you
Best regards,
Message 3 of 37
Hi Lottie04
Just checking in to see if your connection is still working ok?
Message 4 of 37
Hi Lottie04
Ok no problem 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Lottie04
Message 5 of 37
Hi Debbie
Its working fine so leave it as it is for now
Message 6 of 37
Hi Lottie04
That's great news 🙂 Would you still like me to switch the WIFI optimisation off?
Lottie04
Message 7 of 37
Just to let you all know that the new router fixed all my Wi-Fi issues.
Thanks to you all.
Message 8 of 37
Hi Lottie04
You should now be able to receive and send Private Messages.
Debbie 🙂
Lottie04
Message 9 of 37
Hi Debbie
I have not tried, i was told it is off i expect they will contact me now when they read this post.
Message 10 of 37
Hi Lottie04
It's no problem. Once the new router is connected then I will switch off the WIFI optimisation.
I have checked and Private Messages are showing as enabled. What happens when you try and send a Private Message?
Lottie04
Message 11 of 37
Hi Debbie
Sorry i did see your message about optimisation but forgot when i was postiing about the Private messaging , away from computer at times and trying to do too many things at once.
Message 12 of 37
Hi @Lottie04
Wi-Fi optimisation is a facility that TalkTalk can enable/disable for you on the router that is currently connected to the fibre. If they disable it now, it will only apply to your current router, not the replacement. Hence why @Debbie-TalkTalk said :-
"Please let us know once the new router is connected and we can then switch the WIFI optimisation off."
Lottie04
Message 13 of 37
Can somebody disable my Wi-Fi optimisation please, and Enable my Private messages
Thankyou
Message 14 of 37
Hi Lottie04
Lottie04
Message 15 of 37
Hi Michelle
Yes could you please send me the appropriate Router for my Full Fibre and of course i will return one of them.
Amongst the posts it was said that i need Private messaging enabled and for Wi-Fi Optimisation to be switched off, is this something you can help me with or will someone contact me.
Many thanks,
Message 16 of 37
Just to confirm, would you like us to send a replacement router for testing purposes to see how this compares? We would also send a router returns bag so that one of the routers can be returned.
Message 17 of 37
Hi @Lottie04
I think for now I will go for a change of tack. With a red question mark against the Ethernet, let's get a replacement router. I will arrange that with TalkTalk for you & hopefully, they'll contact you tomorrow sometime.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
Lottie04
Message 18 of 37
Hi Keith
Quick answer No. This is what Router states.
Band 1 ( 2.4 GHz )            SPEED                     CONNECTED DEVICES
                                          450mbps                                     0
Band 2 ( 5.0 GHz )       2200mbps                                    2     these are 2 mobile phones
WIRED CONNECTIONS   has a RED question mark
        User PC
The Humax IS a wired connection with cable extenders ( latest type ) supplied by TalkTalk to work with Full Fibre router, strange it does not show?
I have noticed whilst getting above info that on the Dashboard page the My devices box fluctuates between 3 & 5 devices when i change pages and currently it states my Wi-Fi is disabled !! and i cannot switch it back on if i go to settings? Devices now listed as zero.
Funny though just checked my mobile and that is working? so is computer.
Message 19 of 37
Hi @Lottie04
I have just looked up the Wi-Fi specifications of your HUMAX FVP - 5000T, which can only use the 2.4GHz band. Some Canon printers are the same. Do you currently have any devices that connect OK via this band? You can find this out by going to the 5464's main Advanced display which will show the devices connected wired (Ethernet), those connected to the 2.4 & those connected to the 5GHz bands.
Lottie04
Message 20 of 37
Hi Keith
Correct, devices still unable to connect thank you for help so far.
Best regards,
