No external IP address
badtooth76
Message 11 of 11
I have had my full fibre line for about a year now. I would like to say its been great, but it's not been. I have had two big faults with the line. Both times the line just went down with the ONT going red. Both took a few days to fix, but got there in the end.
I must say that getting it sorted is strange. You ring up and say your internet's down, and they send you a link to the internet to get it fixed. But I have no internet - that's why I'm calling!
The line has also out of the blue on many occasions just died for a few minutes or two, even though the ONT box had three green lights. Now over the last few weeks it's got worse. It would go down every night, two to three times, even though the ONT still had three green lights.
That was until a few days ago when it went down and stayed down for hours. Before all of a sudden coming back to life from nowhere. It was short-lived, and before a few hours had passed, it was down again. This time it did not return until the morning, before going down again less than an hour later.
I got in contact with support, and they made me do the normal things to test my setup. They said the line is working fine from their end. Having done all these things and not finding out why my connection was not working - even though I had tried three routers of which all worked on this connection before, and connecting directly to the ONT - I was still not getting an external IP address on any of them.
All said the same thing: no IP address. So support said I need a new router as that would be configured better to handle my connection. But that's the same router as the old one that works when the line is working!
How is that going to fix it if the ONT isn't giving out an IP address?
So now I have to wait and test this new router, which will probably work when the line is working but won't when it's not. It just seems like a waste of time and money.
I could understand if it was just one router, but it's three routers I've tried and two direct connections to the ONT - all fail to give me an IP address, but all work when the ONT is giving out IP addresses.
How is a new router going to fix it if everything works when the ONT gives an IP address, but nothing works when it doesn't? The ONT has all green lights all the time, even when not working.
Having read some of the posts on here about the same thing makes me see I'm going to be in for a hard time getting this sorted. As of right now, I have a fibre connection that works for about an hour a day and then stops.
Ref 15605550
10 REPLIES 10
Message 1 of 11
@Divsec thank you very much for that. Apologies @badtooth76
Message 2 of 11
It's your thread, @nambuso-TT misread. To answer your final question send back the unused one (if it ain't broke don't fix it)
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 3 of 11
This is my thread or post? Am I missing something here? Who's thread is it? How many posts do you want me to make about my internet problem?
Please tell me because yet again I have no clue what your asking me to do, other then start a new post/thread about the same thing?
Message 4 of 11
Hi there @badtooth76 . Could you please start your own thread and we will assist from there.
Message 5 of 11
Yes - looks like I got a duff AI result when I checked that fact. Sigh....
Message 6 of 11
Glad to see things seem to be sorted. And you're right, DLM does not apply on Full Fibre circuits.
Message 7 of 11
I did not think that they had DLM on FTTP?
Just an update so far, the internet has been working all the time from my last post. I have tried using all different ways to connect and they all work now, thats the old Eero pro 6, my TP-link router and direct connections. All of which did not work when I was having problems.
I also have a brand new Eero pro 6 which support sent out, but I don't need it as I told them it was not the router that was faulty. I would like to send them it back, but am not sure if they want my old Eero back and want me to keep the new one? I have not tested the new Eero as the old one is up to date and working fine so there is not point in using the new one. I also have my old TP-link, plus another old router as backup should the Eero break.
So if any members of Talk talk staff would let me know which router they want back the new or the old Eero, I will get it posted back to them.
Message 8 of 11
@badtooth76, give each router a day or two to settle down. Otherwise each time you swap them, Dynamic Line Management will misunderstand and read the drops as faults.
badtooth76
Message 9 of 11
As of yesterday mid day the internet started to work again, using my old router as the new one has not yet come. So far its been working without dropping again, but time will tell.
It's good to have a phone number to call, so thanks for that.
If it stays up for over a day I'm going to test the connection with different routers and direct connections so that I can fully rule out the router as the problem.
Message 10 of 11
At the moment, I think you will need to contact the full fibre helpdesk, as the staff on here do not yet have access to full fibre. The FF Helpdesk is on:-
0345 172 0074
