No ring calls every 30mins since Full Fibre upgrade.
MGColdrick
Message 11 of 11
Ever since i had my Full fibre upgraded for free by TalkTalk i keep getting no ring calls every 30 minutes on my BT phone. I have spoken to TalkTalk support multiple times on the phone but each time i get no solution provided. Last call i was told to wait for an engineer but that has been a week now with no call back.
I see on here that multiple people have this same problem with the solution of a software fix? Would this solve my problem?
Thank you for any help provided.
10 REPLIES 10
Message 1 of 11
Excellent, I'm really glad to hear that 🙂
Message 2 of 11
Hello Michelle,
The issue seems to have been resolved. I have not noticed anymore missed calls.
Thank you very much for the swift fix.
Message 3 of 11
Morning Matt,
Just checking back in to see if you've received any more 30 minute missed calls since my last post?
Message 4 of 11
Hi again Matt,
The team have confirmed that the fix has now been applied so you should no longer see any more of these 30 minute missed calls. I'll check back in with you on Friday just to ensure that everything is ok.
Message 5 of 11
Hi Matt,
Thanks for confirming. I've asked the team to apply the fix for this particular issue and I will post back here to confirm once this has been completed.
Message 6 of 11
Hello Michelle,
Yes correct I have the WiFi Hub 2 with the Voip phone line connected.
Matt
Message 7 of 11
Can I just confirm, are you using the Wifi Hub 2 router please?
Message 8 of 11
As I said, yes, but not until next week.
MGColdrick
Message 9 of 11
Is there any support able to be provided here for my issue?
Message 10 of 11
staff should be able to help when back next week and you are in their queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
