Not receiving incoming calls.
Antoni2
Message 43 of 43
Have been converted to full fiber 11th Nov. New router had not arrived. It came a few days later. Connected ok. Plugged phone ionto back of router. Can make clls OK but found out today that incomming calls not geeting through. When someone calls from a mobile phone they get a message saying cannot connect at present try later. Tried plugging the phone back ito the old copper connection but it no longer works.
42 REPLIES 42
Message 1 of 43
@Philile-TT,
This is @Antoni2's thread. No need to start a new one.
@Judithw62, you need to return to the message board and click on start a topic to begin your own.
Edit: thanks for editing your post, @Philile-TT. 😊
Message 2 of 43
@Judithw62 please start your own thread so that we can assist you.
Phili
Judithw62
Message 3 of 43
Antoni2 did you get this fixed? I am having the same problem now
Antoni2
Message 4 of 43
Thankyou
Message 5 of 43
Glad to hear it's working now, just let us know if you experience any further problems
Antoni2
Message 6 of 43
Bought a phone at the weekend, plugged it in and got my mother’s carer to call me and the phone rang. This morning I went to the GP’s surgery to order some medication and asked the receptionist to cal me and that worked. So I think everything is working now.
Originally I thought the phone was not ringing because the call was getting through to the phone. It wasn’t until Thursday that I discovered that the calls were getting to the phone but they were not triggering it to ring. I don’t think the old phone is faulty just not compatible with VOIP. I still find it a bit strange that everything seemed to work apart from the call not triggering the ring.
Message 7 of 43
OK, please let us know how you got on
Antoni2
Message 8 of 43
So its the RJ45 cable. By small he meant short? There does not seem to be anyone about at the moment to ask to borrow their phone. Also I don’t know if any of my neighbours have full fibre/VOIP or even if they still use a landline. I have been looking around on the internet and there are warnings that old phones might not be compatible with VOIP. I see that there are so called VOIP phones on sale. So I think I will go out tomorrow and purchase one (and an RJ45 cable) and see if that works properly.
Message 9 of 43
Hi Antoni2
Thanks for the update. The RJ45 cable is the Ethernet cable that runs from the router to the ONT. (The cable from the telephone to the router is probably has an RJ11 connector)
Antoni2
Message 10 of 43
Message from Andrew did not come until late last night so could not do anything. I have a busy morning today. I have to do some shopping and pick up some medication from the pharmacy. Don’t know at the moment if I can borrow a handset from some one.
My hand set is an old one, I think we acquired it in the 1990s. It is very basic. Standard BT issue at the time. There is a sliding button underneath with 3 settings for volume, it is set to high.
What is the R45 cable? I googled it but only find an RJ45 cable which is a LAN cable. Does he mean the thin cable that plugs into the handset and the other end into the router?
andrewJ
Message 11 of 43
ok might sound a bit odd check your handset to see if the ring off switch. or ringer volume control.
Also ask your neighbour if you can borrow there hand set and R45 cable that the small cable. see if that work.
it could that your phone faulty or just does not work with  (VoIP)
you can google the model of your hand set for the manual it say in there.
andrewJ
Message 12 of 43
Message 13 of 43
Thanks. I've passed this on to my colleague in the network team 🙂
Antoni2
Message 14 of 43
Yes. I am in all day now. My laptop is logged in to my email.
Message 15 of 43
Thanks. My colleague in the network team would like to send you diagnostics to run through, is it OK to send it to the email address you used to register on the community?
Antoni2
Message 16 of 43
Yes, The GP’s receptionist tred to call me twice. My phone did not ring. She said the phone appeared to be ringing. Then I asked my neighbour to call me her mobile On her phone it appears the phone was ringing but it was not. When I picked the phone up the call connected and I could speak to her. .
Message 17 of 43
Hi Anotoni,
Thanks for the information, just to confirm, you've tested with a second telephone?
Antoni2
Message 18 of 43
Got your messages about 11 pm last night. Shut down my laptop and switched off the router and unplugged the white box. Left them for the best part of an hour. Plugged in about midnight. Waited for the two green lights to come on on the white box then turned on the router. Then went to bed. This morning dialled 123 and gut the peaking clock Ok. Wen to the GP surgery to renew medication and got the receptionist to call me when I got home (a few minutes walk). She tries twice. The phone appears to be ringing but my phone did not ring. Saw my neighbour in the street and asked her try ringing me on her mobile. Sure enough on her mobile it appeared that the phone was ringing but my phone was not ringing. However, when I picked up the handset the called connected and I was able to speak to her. So the problem seems to be simply that the phone does not ring.
Any idea why that might be Something g in settings? Voicemail? The handset isn’t very sophisticated. There are three buttons, secrecy (don’t know what that does), recall and redial.
Any ideas what is stopping the phone from ringing?
andrewJ
Message 19 of 43
This issue can be fixed. turn every off even the fibre box on the wall of for 20 - 30 minuets. you need to get the line to full drop.
then turn in all back on do not use the internet or phone for two hours to give it time to come back and set up.
if that does not call full fibre support.
Message 20 of 43
Our network team need to run through some checks with you, is there any way that you can borrow a mobile phone for a short period of time so that they can do the checks?
(alternatively the network engineer can email a list of the checks if you can't get hold of a mobile)
