Phones disconnect from WiFi
daves01
Message 6 of 6
I have a Motorola g34 (on Android 15) and a Motorola g35 (on Android 14) that keep dropping the connection to my WiFi (EERO 6) - g34 drops occasionally but the g35 frequently loses connection.  I haven't noticed this happening when connected to other WiFi networks so I'm suspecting the fault lies with the EERO and not the phones.  I've turned Client Steering off on the EERO (suggested elsewhere) but the problem persists.  Any ideas, please?
5 REPLIES 5
Message 1 of 6
@daves01, thank you for letting us know, we are glad to hear that this has been working so far. Please do reach out to us if you have any other issues or concerns. We are here to help.
daves01
Message 2 of 6
So, thank you for your replies and suggestions, but after further research and investigation I now believe this is a problem with Android 14 - apologies to EERO.
This means my question doesn't belong here but just for completeness in case anyone else happens upon this post:
I entered developer mode on the g34 and looked for any settings that might stop the phone disconnecting but nothing worked.  My latest 'fix' is simply to leave Whatsapp running on the phone before setting it into standby mode and, whilst I can't monitor 24/7, this does seem to be working so far (touch wood!) and we won't miss any more Whatsapp calls.
Message 3 of 6
Thank you very much @KeithFrench, I appreciate you very much.
Message 4 of 6
HI @daves01
Wi-Fi interference (nothing to do with electrical interference) can cause:-
  1. Slow speed,
  2. intermittent dropouts,
  3. breaks in the signal,
  4. no signal at all,
  5. or no internet access.
This can affect one or more devices. This can also lead to a permanent reduction in the speed of one or more devices. No ISP can be responsible for your local environment; this is mainly a byproduct of the popularity of Wi-Fi.
Generally speaking, the 2.4GHz band suffers far more from Wi-Fi interference than the much faster 5GHz band. However, the 2.4GHz band has a longer range than the 5GHz band and can penetrate walls better. This may very well change depending on your local area.
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves my sending out a guide to help you get important diagnostic information for me. I will then analyse these results for you and recommend changes to your router configuration, if required.
siphosethu-TT
Message 5 of 6
Hi there @daves01, I would advise you ask @KeithFrench as he has more knowledge on this or you can call our full fibre team and they will be more than happy to assist. Thanks
03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
