Poor EERO coverage upstairs
Kiters451
Message 2 of 2
I have had fibre 150 fitted by Open Reach the new EERO was fitted where they said it would better than the talktalk router , with the old router I got coverage all around the house even in my up stair office, Now only working down stairs no coverage in my office at all, this means I cant no use my laptop or printer unless I take them both down stairs near the NEW EERO,
what a load of rubbish, Hopefully TALKTALK can sort this problem as I now have got 18months contract so some thing needs sorting out ASAP.
1 REPLY 1
Message 1 of 2
Hi @Kiters451
I can hopefully help. Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
