Positioning of power points
Mike16
Message 2 of 2
If my power points are positioned low on the wall I doubt I'll get a good signal via the eero having just tried with my current router. But the alternative is to have lots of wires up the wall to  extension cable power points. Is the solution to have two eeros....the master low down and the other higher up?
1 REPLY 1
Divsec
Message 1 of 2
@Mike16 probably worth giving it a try before you go spending money on a second eero?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
