on 17-09-2024 07:53 PM
Pretty fed up with the Wi-Fi coverage in my home. Thinking of creating a MESH Wi Fi system. I have a Sagemcom F@st 5364-3 T8 Modem which Talk Talk advise is mesh ready - although I do not believe them as I cannot find any reference to Mesh in the user guide. So, thinking about buying a TP Link Deco system, maybe the X50..
The question I have is:
1. Is the Deco X50 compatible with the Sagemcom F@ast 5346-3 ?
2. Integration of the X50 (assuming its compatible) - Turn off Sagemcom Wi-Fi and link Deco to Sagemcom via Ethernet port (white) or Red (WAN) connection ?
3. Power up and follow the TP Link Instructions on their App ?
4. Normally the Deco X50 come in packs of three which I can position at strategic points around the home and each unit will connect to the master that is plugged into the F@ST Modem ?
Understand that the Extender F@ST 266 may be a solution ?
If this is a suitable solution then how do I obtain a F@ST Extender and will it provide coverage for my home
on 25-09-2024 08:37 AM
There have been speed issues (not WiFi coverage) that other people have attributed to Norton. I can't comment as I do not use it.
on 25-09-2024 08:31 AM
on 25-09-2024 08:29 AM
Hi Debbie
Any update on the firmware update. I have a VPN client - Norton 360. Please advise my next steps in preparation for the firmware update.
Nigel
on 24-09-2024 08:45 AM
Please see my sticky, the router NUST be running V202 before connecting the 266:-
on 24-09-2024 07:42 AM
on 23-09-2024 08:52 PM
Leave the router on - staff can push through the update if you let them know a convenient time [probably morning, weekdays].
on 23-09-2024 06:40 PM
Hi Community
I am about to connect my new F@ST266 Extender to my F@ST 5364 router. I have checked the firmware of the router and it is SG4K100174 (V174). Understand from the threads in the community that the router should have firmware > 174 ideally V202.
The question is how do I update the firmware to V202 - is this a Push from Talk Talk or can I find it elsewhere ?
Nigel3009
on 23-09-2024 04:07 PM
To get another 266, you will have to contact the loyalty department (0345 1725157).
on 23-09-2024 04:05 PM
Hello Michelle
Thank you for the message, just returned from holidays and a package from Talk Talk is waiting for me. Give me a few days and I will set up and try.
If all works out well and I need another extender. How can I obtain one and what cost ?
Kind Regards
Nigel
on 20-09-2024 08:40 AM
Hi Nigel,
How are you getting on?
on 18-09-2024 03:30 PM
A Wi-Fi Booster is on the way to you.
on 18-09-2024 03:25 PM
Hi Chris
Yes please, this is exceptionally good of Talk Talk.
Look forward to receiving unit and hoping for much improved Wi-Fi coverage.
Kind Regards
Nigel
on 18-09-2024 08:59 AM
Hi nigel3009,
I can arrange to send you a wifi boost to test with, to see if it improves wifi coverage. Would you like me to arrange this
on 17-09-2024 10:09 PM
Hi @nigel3009
I have asked one of TalkTalk's support to pick your thread up and they will advise you.
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture and then clicking on "My Settings" followed by:-
