eero power adapter using extension USB type C cable
Message 5 of 5
The length of the power cord of the eero 6 power unit is OK for some installations. I would like to site my eero in a different location to improve Wi-Fi coverage. However, it would be too far from any power points. Rather than run extension mains cables, which is an option, as the connector into the eero is USB Type C, I was thinking of buying a USB type C extension cable.
I know the eero can detect an unauthorised USB C power source, suggesting that there are some active components in the original length power cord.
Has anyone tried extending it in this manner & how did it go?
4 REPLIES 4
Message 1 of 5
Hi @fr8ys
Thanks again, I was just thinking of buying a cable to extend the existing one, alas anyway that one is no longer available.
Message 2 of 5
Sorry, @KeithFrench
Specifically says compatible so hopefully would be ok.
https://www.amazon.co.uk/Adapter-Charger-Replacement-Extender-C010001/dp/B0B2WLV7Z4
Message 3 of 5
Hi @fr8ys
Thanks for the reply, I think you forgot to add the link.
However, it is not finding a cable, but does it work with an eero? I am trying to see if anyone else has done this before.
Message 4 of 5
Hi Keith,
Does this meet your needs?
Haven't checked but maybe Amazon Basics do something similar.
