Problem Changing Wi-Fi Name & Password
Cormorant71
Message 8 of 8
I did this once before with no problems. This time, despite following the instructions I just get the message “password does not match Wi-Fi name”. I have tried three times to do this. The Wi-Fi name is changed without a hitch, but not the password ! Then I have to reset the router each time to access the internet to have another attempt 😩😩.
Can someone suggest a solution please, as I soon won’t have any hair left to tear out !!!
7 REPLIES 7
Message 1 of 8
How are you getting on?
Message 2 of 8
Hi @Cormorant71 sorry, that's not unusual😀. (table ) and (table) look the same but the first has a trailing space. If you see what I mean. Don't worry the experts here will get you sorted.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
Message 3 of 8
Hi @Cormorant71
Which make/model of router do you have, if it is a Sagemcom, then this is always best done from the Advanced mode. It has to be done twice, once in the 2.4GHz band & once in the 5GHz band settings.
2.4GHz:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 2.4Ghz gear icon > Basic
5Ghz:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
Message 4 of 8
Hi Divsec
Apologies but I have no idea as to what you’re talking about 😩.
Message 5 of 8
Many thanks Debbie. I’m going to try again and see if that’s successful and if not I’ll get back in touch.
Kind regards.
Message 6 of 8
Hi Cormorant71
Would you like me to send a replacement router for testing?
Divsec
Message 7 of 8
Hi @Cormorant71 your post has been escalated but have you checked for leading and trailing spaces? They creep in when cutting and pasting.
