on 30-06-2023 09:57 PM
We have just had full fibre and an Amazon eero router fitted plus a voice adapter - phone, computers and internet working fine but can not seem to connect printer to the computers by wifi. can someone explain the method in simple terms, please?
on 03-07-2023 06:35 AM
Thanks for confirming and please let us know if you need any assistance 🙂
on 02-07-2023 01:03 PM
You're very welcome.
on 01-07-2023 10:37 PM
Hi, Many thanks for your answer. I eventually realised that when my printer was saying WLAN rather than the expected Wifi it was meaning the same - but it really isn't. Anyway I have successfully connected it to one laptop - now later to see if it is connected to my wife's also!
Thank again Keith
on 01-07-2023 11:24 AM
As Keith says, you select the eero network at the printer interface so the printer knows which network it needs to connect to and then if there's an issue connecting to the eero 2.4GHz network it can help by temporarily disabling the eero 5GHz network which is what my advice is.
Here's more advice from eero Support on connecting a printer.
In practice I've found the eero to be easy to use and when I last changed my printer setup from a secondary router on my network to the eero all I did was select the eero network at the printer and the connection was made. Very easy.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
on 01-07-2023 10:40 AM
You have not said which make/model of printer you have & which connection method you are trying to use. I do not think that the Eero router supports WPS (is that correct @Gondola), so you may have to manually select your WiFi network on the printer and enter its password from there as well. Please see your printer's documentation.
on 30-06-2023 10:54 PM
You may need to temporarily disable the 5GHZ network.
There's also advice from the eero Support Hub in the guide below about using legacy mode.
The eero Support Hub is your go-to resource for information, guides and Community support
Select here:
eero Support Hub
eero 6 and eero Pro 6 Help
eero - Problems connecting a device?
