Won’t connect to printer!!!
Message 11 of 11
I run a small business from home so need this sorted asap ideally. I bought a new printer and it will not connect through DNS settings. I called Epson and they said it is a router problem, and my router settings need to be adjusted in order to allow the printer to connect to the rest of the network.
10 REPLIES 10
Message 1 of 11
To be honest I don't know what setting they are talking about. You could try resetting the router to factory default settings - Restore your router to factory settings - TalkTalk Help & Support
Message 2 of 11
@Chris-TalkTalk @Anonymous I have spoken to Epson again who have said it’s a router problem and the settings need to be enabled for ET-2860 on your end. It’s something to do with the DNS connection security as it ‘cannot be verified’
Message 3 of 11
Message 4 of 11
So you've not had a working printer on your home network?
Message 5 of 11
@Chris-TalkTalk yes, this is actually my second printer as the last one had the same problem! Got rid of it because I assumed it was a printer fault, but this printer is a whole different brand.
Message 6 of 11
Hi Rishaintimeperrett,
Did you have a printer before the new one? If you did, did it work OK?
Message 7 of 11
@Anonymous  it says the security of the IP address of the router cannot be verified. The ip address is the same as showing on the back of my router. I have tried through my phone and computer and it says failed each time. I spoke to Epson and they said something needs to be enabled your end to allow it to connect to DNS settings.
I have updated my profile information
Anonymous User
Message 8 of 11
Has this printer previously been able to connect ok to this router? What happens when you try to connect, do you see any specific error messages? Have you tried re-setting the router and setting it back up again?
  • Name
  • TalkTalk Telephone number
  • Alternative contact number
Message 9 of 11
@Anonymous  It is Sagemcom-FAST5364
Anonymous User
Message 10 of 11
I'm sorry to hear this. Which router are you using please? (make and model)
Anonymous User
