on 27-02-2026 06:13 AM
Hi, need urgent help! I've received a new router (Sagemcom FAST 5359) as part of a home move to a full-fibre service. I cannot connect my work laptop which uses a Cisco Anyconnect VPN to access the companies network. I have been speaking to talktalk (lapwing?) who have turned on/off some scam filters but nothing has worked and they are saying it's my companies VPN that's the issue (this works fine with other connections). I have seen similar posts from 2024 in this forum that seem like it's an issue with router firmware. Can anyone help here? Thanks
Tuesday
You are most welcome. I will get back to you just after I speak to her.
Tuesday
Thanks @Philile-TT
Tuesday
@KeithFrench I will speak to @Nicolene-TT and get back to you.
Tuesday
This Hub 3 must be faulty, as it will not update its firmware automatically. The customer @BenTh has tried rebooting the router & then a factory reset, but still it won't update. Although I have never seen V4200, it must be way older than the current one, V4A00.
Please could you therefore replace the router for me?
Monday
@BenTh we still awaiting information from the team.
Monday
Hi @BenTh
I have already chased my contact & am waiting for a reply.
Monday
Hi all, is there any update to my issue with my router and VPN connection? - when we left this on Friday evening there was an outstanding query regarding my router firmware version that I hadn't been able to update.
Thanks all for your ongoing help, Ben
on 27-02-2026 04:01 PM
Hi @BenTh
My contact in TalkTalk is checking for me now.....
on 27-02-2026 03:51 PM
Thanks Keith, I've done a factory reset but unfortunately this hasn't triggered a firmware update either. Thanks for your ongoing help 👍
on 27-02-2026 01:06 PM
Thank you so much for the support @KeithFrench
on 27-02-2026 01:04 PM
Hi @BenTh
In addition to the escalation done by @Philile-TT, I have also escalated this to a contact that I have within TalkTalk. When I hear back, I will update the thread.
Sometimes, doing a factory reset on the router will force a firmware update. You could try that if you want.
on 27-02-2026 12:19 PM
@BenTh we will be escalating this side, and we will advise you once we have a response.
on 27-02-2026 12:03 PM
Hi Keith, I've tried a reboot and it doesn't pickup any update - still the same firmware
@Philile-TT for info above, could you please tell me what I should do next - do I contact anyone else now to progress this, or wait for a response here from the other people in this thread?
on 27-02-2026 11:17 AM
That great. Thank you @KeithFrench for all your help.
on 27-02-2026 11:16 AM
Thanks @Philile-TT. I have also just PM'd Lorraine about it as well.
on 27-02-2026 11:15 AM
@KeithFrench I will also pass on the message to @Nicolene-TT .
on 27-02-2026 11:13 AM
That looks like it is very old firmware, certainly one that I haven't seen before anyway. Please can you reboot your router to see if it will pick up 4A00.
This customer has a different firmware version on the WiFi Hub 3 that I haven't seen before (4200). However, it looks older than the one that I believe is the current version, 4A00. Please can this be passed to your Devices team to confirm the current version?
on 27-02-2026 11:07 AM
Hi Keith,
Just looked, it's different
Firmware Version: SGEK10004200
on 27-02-2026 11:00 AM
IPSec, alas, is the one I cannot check, as there are no free IPSec VPN servers to test against. I would suspect that there could be a bug in the WiFi Hub 3's firmware, but first, I need to make sure that you are using the current firmware. If you go to the router's login page in your browser, typing its IP address of 192.168.1.1 by default, look at the bottom of the page under the login section. The firmware should end in 4A00. Is that the same as yours?
on 27-02-2026 10:27 AM
Hi Keith, just looked into settings and against protocol it says IKEv2 / IPsec NAT-T
