Connect spare 3rd router
Funky-Gibbons
Whizz Kid
Message 6 of 6
@KeithFrench could I trouble you for your expertise please, on my daughters property I have previously linked a spare router to help with a signal dead spot which has worked fine, what I am wondering is can this be done with another spare so 3 routers are linked?
At the moment she has a Sagecom 5464-2.T4 as her main router with a Sagecom 6364-3.T8 linked via a powerline adapter. If it is possible I presume the process is just the same but how would I need to alter the ip address on the 3rd router. At the moment it has 192.168.1.1 on the main router and 192.168.1.2 on the second
Ready to learn something new today
No longer a TT customer, but like the community.
5 REPLIES 5
Message 1 of 6
That's great, thank you for your help
Message 2 of 6
.3 should be fine.
Message 3 of 6
Sorry Keith that was a typo or failing eyesight! It is a 5364. Anyway in regard to the ip on the 3rd router should I put it exactly as I have used on the second one or would it need to be 192.168.1.3
mandisa1-TT
Message 4 of 6
Thank you for the support @KeithFrench.
Message 5 of 6
Yes that should be no problem, although I have never heard of the 6364.
