on 27-02-2026 06:13 AM
Hi, need urgent help! I've received a new router (Sagemcom FAST 5359) as part of a home move to a full-fibre service. I cannot connect my work laptop which uses a Cisco Anyconnect VPN to access the companies network. I have been speaking to talktalk (lapwing?) who have turned on/off some scam filters but nothing has worked and they are saying it's my companies VPN that's the issue (this works fine with other connections). I have seen similar posts from 2024 in this forum that seem like it's an issue with router firmware. Can anyone help here? Thanks
on 09-03-2026 12:32 PM
Hi @BenTh I have placed thee order for the WiFi Hub 3 to be sent to you and it will be delivered within the next 2-3 working days.
on 09-03-2026 12:24 PM
I have received the details, I will place the order for you now.
on 09-03-2026 10:22 AM
Appreciate your help @KeithFrench on this thread.
on 09-03-2026 10:20 AM
Thanks @Lorrainef
on 09-03-2026 09:59 AM
Understood @Lorrainef . I’ll get the replacement router arranged. @BenTh please private message me your full delivery address so I can complete the order.
on 09-03-2026 09:48 AM
@Philile-TT Hi, can you please send a replacement router on this one, thank you.
on 09-03-2026 09:26 AM
Hi @Philile-TT
@Lorrainef advised me last week that the router was to be changed out, as the problem is most likely related to the firmware that will not automatically update itself. This is despite me asking @BenTh to both try a reboot & when that failed, a full factory reset of the router. Please see my post #23 on this subject.
on 09-03-2026 08:50 AM
@BenTh Hi there. We have been awaiting feedback regarding this, however I was advised that the issue may not be with the router because everything else is working it is just with your work laptop this could mean there is something wrong with the laptop.
on 09-03-2026 08:46 AM
Hi all, is there any update to my issue with my router and VPN connection? There has been no change to the issue, I still cannot get this working. Thanks
on 03-03-2026 10:55 AM
You are most welcome. I will get back to you just after I speak to her.
Thanks @Philile-TT
on 03-03-2026 10:51 AM
@KeithFrench I will speak to @Nicolene-TT and get back to you.
on 03-03-2026 10:45 AM
This Hub 3 must be faulty, as it will not update its firmware automatically. The customer @BenTh has tried rebooting the router & then a factory reset, but still it won't update. Although I have never seen V4200, it must be way older than the current one, V4A00.
Please could you therefore replace the router for me?
on 02-03-2026 12:58 PM
@BenTh we still awaiting information from the team.
on 02-03-2026 12:55 PM
Hi @BenTh
I have already chased my contact & am waiting for a reply.
on 02-03-2026 12:00 PM
Hi all, is there any update to my issue with my router and VPN connection? - when we left this on Friday evening there was an outstanding query regarding my router firmware version that I hadn't been able to update.
Thanks all for your ongoing help, Ben
on 27-02-2026 04:01 PM
Hi @BenTh
My contact in TalkTalk is checking for me now.....
on 27-02-2026 03:51 PM
Thanks Keith, I've done a factory reset but unfortunately this hasn't triggered a firmware update either. Thanks for your ongoing help 👍
on 27-02-2026 01:06 PM
Thank you so much for the support @KeithFrench
