Ring doorbell wont lik to new Talk Talk Router
Simon4848
Message 5 of 5
I've upgraded my router, but my Ring doorbell gen. 2 won't find my WiFi. It says it will o ly work with a 2.4hz network.
My router is dual channel 2.4 and 5mhz. Is there a way of setting up the router so the doorbell will see the 2.4 mhz channel. I looked on the router site and the 2 channels appear separate? I'm not very technical so didn't change anything.
4 REPLIES 4
Message 1 of 5
Morning Simon,
Do you still need assistance with this?
Message 2 of 5
Hi Simon,
What is the make and model of the router that you're using please and also which router were you previously using when the Ring doorbell worked ok?
Message 3 of 5
Hi Simon,
How are you getting on?
Divsec
Message 4 of 5
Hi @Simon4848 if you were able to access the router gui (graphic user interface) to learn about the WiFi you might have been able to disable the 5ghz channel temporarily this should allow you to add the door bell.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
