on 31-03-2024 01:41 PM
The 5Ghz network on my router keeps stopping and my speed then drops by about half. I have to restart the router to get it back up and the speed then restores. I have logged in to the router and it looks to be up but it is not visible to any of my devices. This happens at least once a week.
Its a Sagemcom Router.
Serial NumberHardware VersionSoftware VersionGUI VersionSystem Up Time
| N7230319K007906 |
| FAST5464 2.00 |
| SG4K100174 |
| 5.100.1 |
| 6d 14h55m06s |
on 03-04-2024 06:45 AM
No problem 🙂 Please let us know if you need any assistance.
Michelle 🙂
on 02-04-2024 07:44 PM
on 02-04-2024 06:59 AM
on 01-04-2024 10:43 AM
Hi @js270575 unless this sorts the problem, please collate the screenshots I have requested in my guide & PM them to me to preserve your privacy.
on 01-04-2024 10:22 AM
Hi @js270575
I've switched the WIFI optimisation off, please let us know how the connection compares.
Thanks @KeithFrench
on 31-03-2024 10:03 PM
I have asked TalkTalk to disable WiFi Optimisation for you, they will post on here when done, but I don't expect it will be until after tomorrow.
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
on 31-03-2024 05:55 PM
Hi Keith,
Please can I request to disable Wifi optimisation as i dont believe its been disables before. Also please could you send me the guide
thankyou
on 31-03-2024 03:23 PM
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
