Router is blocking work VPN
Haylzzx
Message 34 of 34
Hello my router is blocking my work VPN so I am unable to work from home. I have recently moved house and I am using the same router as before. I had previous problems with this in my old address but this was resolved. Perhaps the firmware needs to be updated? It is very important I am able to connect to my work VPN in order for me to work. Please help.
33 REPLIES 33
Message 1 of 34
Hi @Haylzzx
I couldn't find a download link, please can you give me the link? If it is free, then I will test this client, rather than just using another one that uses PPTP.
Message 2 of 34
Thank you keith. Yes its available on windows. Hopefully they can resolve soon. My I.T department have been trying all day.
Message 3 of 34
Is Pinnacle available for Windows?
Just in case your router is faulty I have asked one of TalkTalk's support to pick your thread up and replace it for you.
Message 4 of 34
@Karl-TalkTalk @Debbie-TalkTalk @Michelle-TalkTalk could one of you please help me as you managed to help resolve this before.
Message 5 of 34
Yes tried that still hasn’t worked.
Message 6 of 34
Hi @Haylzzx
I have proved that it is not the router that is blocking PPTP. Did you try my other suggestion about using the Google DNS servers?
Message 7 of 34
It worked fine with this computer and router before I moved house? Talktalk had to fix it previously when i first started working from home. But since I have moved house I now have the problem again.
Message 8 of 34
Hi @Haylzzx
I have just tested this, using the Sagemcom 5464 Hub 2 running firmware V206 & can confirm it all works fine with a PPTP connection to the normal TalkTalk VPN servers.
Are you sure that there is nothing on your PC that is blocking this when using your router?
Message 9 of 34
Hi @Haylzzx
PPTP is always one of the VPN protocols that I test & it passed OK when I first tested V206, prior to its general release. I did have a problem with it this morning (not over a Sagemcom) and tried it with a different VPN server to the standard TalkTalk ones (Google DNS - 8.8.8.8 & 8.8.4.4) and it worked the first time. I will retest again with a Sagemcom in a while, but in the meantime, if you want to try Google DNS you can do it by logging into the router & going to:-
Dashboard > See internet settings > Manage advanced settings > Internet connectivity > DNS IPv4
Then change the DNS dropdown box to Manually Specify DNS. Then set DNS 1 & DNS 2 as mentioned above.
Message 10 of 34
Thanks Ferguson.
Message 11 of 34
There we go, your VPN is provided by Pinnacle. That's a good next step.  🙂
Message 12 of 34
@Karl-TalkTalk the error I am receiving is ERROR 807 which means my router is blocking the PPTP. I have put my router details into my private notes please check firmware to ensure this is not being blocked. Thank you so much and I hope for a speedy resolution.
Message 13 of 34
If they use their own VPN client, we have no way of testing this to see if it is blocked in any way. Please find out which VPN protocol it uses
Message 14 of 34
I just called my IT desk and they said the company runs off its own VPN
Message 15 of 34
Then you need to check which VPN client you are using, as there are no known issues with any VPN clients on V206. Karl will tell you the same.
Message 16 of 34
Yes I did that and it didn’t work
Message 17 of 34
Hi @Haylzzx
Did you do what I requested about turning your router & ONT off for at least 30 minutes to clear any remaining sessions?
Haylzzx
Message 18 of 34
Still have this problem. Please help @Karl-TalkTalk
Message 19 of 34
Hi @Haylzzx
Try my other suggestion first.
Message 20 of 34
Thank you Keith, i will try and get the information from my IT department when they come back. Its out of hours until 2nd January so knowledgeless staff on call.
